I'm putting these tires on the front end of my Spyder. They have no balancing dots on the sidewalls, but there is a blue dot inside on the tread portion. Can anyone here tell me if this dot is for balancing?
Thanks!
Printable View
Thanks!
This article should shed some light on tire dots. https://www.tirebusiness.com/article...erve-a-purpose
Thanks Ann, Always learn something new on this forum. "Red dot"--- thought it's a sighting device for firearms------ I'd rather have a laser.
Lew L
Mr Lew,
I took my front tires and rims to a car tire place with a road force balancer. That is a great machine. Adjusts the high spot to work with the out of balance condition to give you a tire that runs true with the minimum amount of weight. Some places are a little uptight about putting car tires on a motorcycle rim, so I tell them it's for a trailer.
Thanks h0g,
In a similar vein----- When I had the rear tire (Altimax)installed on my RT, the tech rotated it on the rim to get a balance with NO weights. Wish they could have done that with the new Vredesteins fronts but they took very little balancing weights. nojoke
Lew L
All three of my OEM tires/wheels had a crap load of weights stuck on from the factory. All three wheels balanced out nicely with one weight each with the car tires installed (Vredestein Q5 fronts/Cooper CS5 Ultra rear). After that, I put appropriate amounts of Ride-On sealant/balancer in each tire. Rides/tracks perfectly...
Thank you Ann for the link! And thanks to all for your input.
