Thanks to all for the advice.:2thumbs: I have ordered two of the Powerlets and a cable that I can plug a regular cigarette lighter fixture in if needed.
Printable View
I have searched little and trying to figure out where would be nicest place near dash to put normal size +12 outlet, is there enough room in some spot for Spyder RS?
I'm assuming you meant 'same' spot. I have the powerlets installed. If you go with the 'auto' outlet, the hole req'd is 7/16" larger; it requires a 1.125" hole. You may want to get a measurement; there may be a problem due to the curvature in that area. I believe this is what you mean by normal size:
http://www.powerlet.com/product/pane...rette-socket/6
The other way to go is, purchase this type of plug assy;
http://www.powerlet.com/product/10-p...ocket-cable/10
Then, you can install the powerlet outlets.
By the way, the spyder shown above is a GS and I believe the dash is the same on the RS.
I just checked my GS and based on the cigarette outlet (from powerlet) requiring a 1.51" jam nut, I couldn't find a good place on or near the dash.
Powerlets are the way to go. They are also shorter depth and you won't have to worry about clearance behind the dash.
I just watching good place to normal size auto outlets and I think that maybe side of the "console" or "dash" would be some good spot? Maybe in fast speeds it not safe but, maybe it would work?
http://i10.aijaa.com/b/00947/7232811.jpg
I'm about to install three power plugs, thinking more is better. I notice that most of you put them on the dash and was going in that direction, but then I got to thinking my radar detector has a long cord as does my GPS, which led me to thinking that in the fruck would be smarter so that the extra cords would be hidden in the fruck. When you park, I imagine that you will be locking your helmet in the fruck, so putting the detector and the GPS away as well.
Any thoughts from people that already are using these?
Thanks.
