Blog-My first self inflected problem
Well against my better judgment I did something I knew could be a problem and now I'm paying for it. :gaah:
After riding a RT with the shocks cranked all the way up I knew that's where I wanted my shocks too. I asked one of the BRP guys if they could crank it up for me because I was afraid of breaking the cast cam adjuster. I had several guys tell me they do it all the time without jacking up the Spyder and taking the load off. I still thought it was not a good idea and they were going to take care of it. Well I know these guys were running around like chickens with their heads cut off last night and somehow it got overlooked. No big deal I just packed up and headed out.
At my first gas stop I decided to get the tool out and give it a shot seeing I had 6 hours of riding ahead of me and I might as well have it nice and stiff. This was one of those times when I should have listened to the voice in my head that said just wait till you get home and do it.
I cranked the right side up no problem so I'm thinking cool, this is going to work. Then I moved to the left side and "pop" :shocked: :yikes: sure enough I broke the corner of the cam. Now it's not bad but it's not good either so I got on the phone and the end result was they towed it back to the hotel and when the support team gets back from their ride they can fix it and I'll head out in the morning.
So bottom line if you're going to adjust your front shocks up on the RS or the RT you really need to take the load off of them before you start cranking on them. nojoke
I guess this is the kind of stuff that makes for a good story any way. :doorag:
Left versus right shock adjustment
I am not sure that jacking the front helps much so don't feel guilty!
There is still a substantial pre-load on the springs even when the wheels are off the ground. After adjusting the right shock without much effort, I thought I could do the same on the left side. After applying much more force to make it move, the collar spread around the shock tab instead of going up one notch. I am sure there is something about the direction of the wind of the spring that appears to consistantly cause the issue on the left side instead of the right. Lube may be a solution but I really don't thing we should have to wash the bike after a simple shock adjustment. I have not seen the BRP billet adjuster option in person but it appears to be stronger in this area.
Enjoy the ride and keep up the great reports.
