Every summer I tore the Western States and always have a concern that I might not make it to the next gas station. I'm thinking this might work.
Printable View
Is that resting/affixed to the swing arm(?). If so, would the vibration from that cause any extra sloshing of the gas...I'm not sure if that even matters. What about scratching the upper plastic of the swing arm?
:2thumbs:
To each his own. I would not do it. I think a lot of things could easily go wrong with this setup.
I've never had a problem getting from one gas station to another. And I've been back and forth across the US more than once. The key is to get the fuel tank full. I think very few actually do this.
I'm pretty sure that two things will occur Gas expands from heat from the sun ….. shaking that container may also cause it to expand …. Lashing it down securely will be necessary ………….and then you have un-lash it to use it ………… I carry 1.5 liters ( or almost 1/2 gal ) of gas in a " Burnetts " plastic Gin container in my frunk..... never any drips or even smell ( the cap is made to be safe with alcohol ). My 1330 engine will go about 18 miles if I run out...… Yes it's dangerous to carry spare gas , but there is lot more gas in your Fuel tank and No one worries about that !!!! …...…….jmho …. good luck …. Mike :ohyea:
I rode across the country from Las Vegas to New York in 2017 and was NEVER close to running out of gas. When you get to 100 miles start looking for gas. You could even get the Gas Buddy app for your phone.
NO WAY. Don't strap anything on the drive shaft
:agree: I'm with Kid! I wouldn't be strapping ANYTHING to the driveshaft, especially not gas & doubly so not in a 'not quite as strong as steel' container! Others are worrying about the damage that rocks & gravel will do to the metal shock & the underside of the Ryker, & you're considering fitting a placcy fuel container?! :dontknow: And how will that lashing ever prevent the tall thin container from falling off its narrow perch & in onto the wheel or getting crushed under the seat when you hit a big bump & the arm gets pounded up onto the stop? :shocked:
Another consideration, putting extra weight there on top of the driveshaft/sole suspension arm will be a significant increase to your unsprung weight, so it'll be extra hard for the shock & coils spring to control the movement, potentially overheating things as well as upsetting your ride & handling, & quite likely changing the Ryker's behaviour fairly significantly - and not for the better! :shocked:
I don't think it's such a great idea..... but if you were to strap that container onto the left side of the max mount so it's up out of the way..... :2thumbs:
Sometimes I quote the entire post and just highlight what I am commenting on. I guess I should do that all the time. But I figured you'd know in what context you posted, so I just pulled out the statement I wanted to reference.
I assumed your original point to be that since there is 6 gallons or so of fuel in the designed fuel tank, it's no big deal to add a lesser amount of fuel somewhere else.
My point is that potential hazard lies not so much in the amount of fuel stored, but in the location, method of attachment, and container used. This has a lot to do with potential for something to go wrong. The designed fuel tank on most vehicles is a very safe place to store fuel.
I assume you are encouraging the OP to go for it. I want to encourage the OP to re-think his project. Just 2 opinions. His decision. Anything more or less than this was unintentional and I apologize if I went about this the wrong way. I'm definitely not here to make anyone upset.
In my years in the fire service I saw what someone thought was a good idea for transporting fuel. I think this OP's idea is a bad one. I could be wrong. It's his decision. But I'd hate for him to find out that I was right. I don't want to see anyone hurt. Running out of fuel and getting a tow or paying someone to bring you fuel can sometimes be the better option.
we ride on the HALF TANK RULE.... we start looking for a gas station once we are at half full... also, if we stop for a rest-room, or water or anything else and the place has gas, we fill up regardless of how far we've traveled since the previous fill-up....
First, the RotopaX fuel containers are bullet proof, not thin plastic, used by dirt bikers and off-road 4 wheeler's alike, and they do not leak under pressure. No problem there. BUT, I'd also think twice about tying one on with a bungee cord, regardless of where it was placed. I'm not sure the one in question is actually mounted to the swing arm but even if not, it is too close to the swing arm and tire. And if you travel in the west (West Texas comes to mind...) there are stretches where there is no gas for 100 miles. Same goes for the Alaska Highway (any number of the gas points that were there on my first trip are now closed.) So even with a 200 mile range, I never pass up fuel when it goes below 1/2.
I appreciate your responding to my comment about your post QUOTING me …. #1. your 4th paragraph … " I Assume " - well you Assumed wrong. I wasn't encouraging the OP to do what He asked about. My first two sentences addressed Expanding fuel, this is dangerous for a lot of reasons. I fail to see " encouragement " there..... #2. - From the photo's I couldn't tell what or how it was attached. I didn't even recognize it was a Ryker..... # 3. I stated it was Dangerous to carry extra separate Fuel …. #4.- I only stated what I did to prevent getting stuck without gas. …… I could show you hundred's or even thousands of Photo's of what Has happened when a Veh's " OEM " safety gas tank " explodes and catches fire...… and if you happen to be of the opinion that the OEM Spyder gas can't or won't in a severe accident - well good luck with that ……. I hope this post Clarifies things for you ……. Mike :ohyea:
Nice Idea but not the best place. True those are tough gas containers and used by off roaders on rough terrain but they are attatched to a fixed location. The swing arm is not that and would be stressing the mounting system to where you may be waring through, cutting into or breaking the container. You could make a bracket off the frame or seat mounting the gas container to it allowing the swing arm full movement and keeping the container moving pretty much the same as you and your normal gas tank... I always look for a station when warning light comes on and carry a liter metal fuel container in case but have never had to use it. When ever we stop to rest and eat I will top off and always try to start off with a full tank. :thumbup:
Looks dangerous. I would not do that. Instead, carry a siphon hose. We have carried one for years, and never needed it.
+1 and maybe include the same gas can...empty
I see you do not have the right side bag. Perhaps if you got the bracket for the side bag that would provide a much improved mounting option for the fuel container.
I understand that dilemma , I have wanted to pull posts also ….. Annnnnnnnnnnnnnnnnnnnnnnd apology accepted, :thumbup:…. the written word leaves lots to be desired. It appears in todays world when you, me or anyone makes even a simple statement, it has to be followed by 20 more " Clarifying " statements so the orig. isn't mis-construed. I have always felt … face to face verbalization to be best ……. Thanks …. PS before the new Administration arrived there were Very many folks who claimed to read minds …. and would then post what you REALLY said :roflblack::roflblack: ........ there isn't much of that here anymore, and I don't miss it even one bit ……… Mike :ohyea:
That's what I carry..... plus a fuel transfer container. The siphon hose is compact. Clear plastic tubing with a squeeze bulb in the middle. Cheap at any auto parts store. My fuel transfer container is a 1-gallon freezer ziplock bag. I have never needed to use either. But they are part of my regular spares on the bike. Together they might weigh 1/2 pound..... Jim
I agree with that. I have a couple of those Rotopac containers. They are very tough. Never had one leak or slosh out. Alaska Highway, you will need extra fuel. Some of the larger National Forests you may have a problem getting fuel. Most of the country there are plenty of gas stops.
It is easy and cheap to fix a strong Aluminium plate on the top of the mount-max - I wouldn`t see a problem to add a fuel-box under my topcase .. but you need a really strong shock on the back (I use the FOX also for 2up - maybe that fits also on the Rally ??
(that story here looks more than dangorous for me )
