2 Attachment(s)
Watch for Wires rubbing against frame getting cut!
I have a 2020 RTL and pulled the panel above the Frunk and below the windshield. I am going to install an additional light power distro block and wanted to have a look at where it will sit. I pulled the panel and found two wire harness connectors. The black one was sitting vertically; the wires were sitting against a metal bracket. I reached in and ran my finger along the edge. It felt sharp enough to cut skin. Closely examined the wires and discovered they are starting to be compromised. The white/green was the closest to being shorted on the frame. Do yourself a favor and pull the Tupperware and have a look. I added some foam in the event the harness wiggles its way back.
