I have not had this happen yet,but……
How many folks out there have had damage done by rocks caught between driven sprocket ?
Trying to justify the purchase of a belt guard @$50.
I’ve ordered the guard.
Printable View
It happened to me. A rock about the size of a pencil eraser. It put a hole completely through the belt. New belts are about $300.00 and the stealer was about $200.00 to install. And then I had to correct their belt tension and alignment. I put a guard on and never had a rock problem again..... Jim
There are plastic and metal guards. Have read here somewhere that the plastic is preferable in case something lodges between the belt and tire the plastic will disintegrate but the metal may jam up and damage the tire. I have half mile of gravel to get to tarmac and have same concern as well as occasional necessary ride on gravel for road construction, detours, etc. Very little room for a guard between belt and tire, have not made a decision as many have ridden years w/o issue. CANAMJHB mentions the obvious potential. Anxious to hear more.
Vendor here Spyderpops has what you need.
OEM belt was damaged by a rock. About $500 to get it replaced by the dealer. Bought a plastic belt guard and it was junk. It either rubbed the belt or the tire and was supposed to be mounted with double-sided tape. Just how long would that last. Here's the belt guard I ended up with.
https://customspyderworks.com/collec...-for-spyder-st
A belt guard was one of the first things I added to my:spyder2:
Lew L
The Custom Spyder Works aluminum belt guard comes with 2 self-taping screws. So you only get one shot at mounting it correctly. Yes, lift the back of the spyder to give yourself better working room. Also if you can, secure the guard some way after you position it properly so it doesn't move around while you're installing the guard. You can call Custom Spyder Works and they can help with any other install questions you may have.
