Spyder RT front tire size change
Does anyone know what size tire for the front you can use in place of the 165/65/r14? I am looking for a good tire for wet, dry and sandy roads with a H rating? To get them without buying the stock tires which one came apart inside with less then 5K on it. I can't find any in the stock size but don't want to have to mod my fenders either? :f_spider: RJ
Tight fit, but it fills out the wheel well nicely w/o any needed modding
I JUST FOUND THIS TIRE SIZE ???
I didn't even know they made this size 185/55-14.......I don't know what the circumference or width is but I am going to find out.....Nice looking tread pattern and " V " speed Rating........Mike..:thumbup:.......It's a Yokohama S.Drive $ 77.86 @ onlinetires.com--------Just put in the tire size and it will go direct to this tire + 4 others.........More info the circumference = 945 revs per mile vs. OEM @ 926......and the width will fit under the fender.....The big difference is the footprint of this tire is HUGH 6.7 INCHES and only a hair wider than the 185/60-14.....The OEM tire only has a 5 inch footprint. :2excited:
Different sized front tires
Do you folks with the bigger footprint tires notice any significant handling differences from the OEMs? With a stiffer set of tires, I'd imagine something would show up. Then again, what do I know?
Thanks
Tuck
Run flats on a 2012 RS Spyder
The Altimax tires look fantastic I wonder if they would fit my 2012 Spyder RS with a good fit and not rub the fenders, but has anyone found and put on run flats for the front and rear tires? Any recommendations close to stock sizes?
