Front turn signal on mirror wire color
I'm at my whits end. Does anyone know the wiring color or where the mirror blinker runs to? At the mirror there is a pair of solid black and a solid white wires and it goes goes into a plug. It then runs behind a panel that goes around under the headlights. I can't figure out how to remove it. The wire goes into the main wiring harness but has a leg that branches off to who knows where behind that panel. The main goes toward the top A-arm where there are 3 plugs but there isn't any solid white wires. :banghead::banghead::banghead:
I need to connect a wire for the turn signals on the A-arms to blink that I got from TricLed. There isn't a way to connect that wire at the mirror because there isn't a hole to go through nor room to splice into the wire.
Does anyone know where these wires go?
