Quote:
Originally Posted by
Lamonster
VSS does not recognize my trailer on my RS and has not been a problem for the last 30,000 miles. I'm pretty sure the RT will handle it much the same. May not be as good as it could be but should be fine.
Here it appears that some computer programs make ajustments
When a trailer is towed, it is required to
set the trailermode in the infotainment
center so that the vehicle uses a different
engine RPM treshold to downshift
earlier than without towing a trailer.
This will also adapt the upshift operation.
Refer to
SETTING THE TRAILER
MODE (p.90) to set it.
NOTICE
If the trailer mode is not
selected through the infotainment
center before towing a trailer, engine
components might be damaged.
All Models
The VSS ( stability system) on the roadster
RT series incorporates a program
that allows to tow a BRP trailer while
maintaining appropriate vehicle stability
control.
