2 Attachment(s)
just short update on my painting of trailer parts
Just wanted to show how the VHT SP402 finish looks after applying a high gloss clearcoat ! WOW - talk about close to BRP color :yes::yes:
I applied 3-4 coats using Rust-oleum Universal High Gloss Durable Topcoat from a spray can! In case you don't know, this line from Rust-oleum comes in spray cans that actually spray with a pattern just like a spray gun would ! Easy to use at any angle and sets/dries quickly in between coats (5 minutes recommended).
Note this was put on parts with the common "dimpled" texture. I'm sure if I wanted to I could put on enough coats to make it look totally smooth, but why :dontknow::roflblack::roflblack:
Anyway, doing the cargo top maybe tomorrow. Incidently, these were sprayed clear after only 2 days of the VHT drying. I actually did a test "plastic bottle spray" last night with VHT, and this AM with the clear, and NO problems at all. :yes::yes: So waiting 7 days like the VHT can says.....:dontknow: your call :roflblack::roflblack:
Anyway, just thought some might like to see/know :ohyea::ohyea::popcorn:
