Would this power make everyone happy??/
Quote:
Originally Posted by
BLUEKNIGHT911
:yikes: ........ Google it ..... Mike :thumbup:
https://www.usatoday.com/story/news/...5-mph/2516457/
Bill Warner (Fish Farmer) was one of the nicest quiet type guy--no ego problem--that I've ever met.. Running on the Loring Air Force decommissioned B2 bomber airstrip in N. Maine. 1/2" pavement difference in the 4 mile runway was perfect for land speed racing. Bill hit 311 mph in the 1.5 mi run but was trying hard for 300 mph in the one mile. 292 mph was his best on a prior run. Personally I loose the ability to process data above 175-190 mph--tach-shift points-track bad spots--cross wind bursts. It enables me to understand that most Formula 1 racers have Mensa IQ ratings. Land Speed Racing is a very high risk sport. Lucky for us the Spyders can't reach 50% of that speed.
Darrell
3 wire into 1 pigtail jumper with push on connectors for dyno test
blacklightning
I would think that they come up with their claimed hp by possibly doing an engine dyno test. No one (car, truck, bike, or trike) really gives an accurate rwhp number. I would think that you should be able to possibly strap a spyder down on a car dyno. I am probably wrong about this, but I do know that most motorcycle dynos that I have seen were too small to put a trike on.
I actually think it would be fairly easy. Locate the 3 wheel sensor wires going into the ECM label & cut the 3 wires---install a 3 wire into 1 wire pigtail jumpers with push on connectors for easy return to normal after the test.. Connect the rear sensor input & both of the floating front wheel input sensor wires & connect the output lead of the 3 to 1 input to the rear senor input on the ECM. Now the front wheels could be stationary--lifted up same height as rear on makeshift ramp or jack stands. That's the whole process. Reconnect cut wires with push on terminals back to original location after the dyno is finished. I'll find & prep the ECM wires & run a dyno this Spring-Summer.
Darrell
