Looking for any solution as to where the oil leak is and causes. Bike is currently at the dealer & they will contact BRP. Has anyone solved this issue. Thank you, Dave:gaah:
Printable View
Can you provide more information? One can see a lot more of the F3 engine than on an RT. Have you looked under your Spyder? What do you see that is an indicator of oil leaking from somewhere? How bad does the leak appear to be? Is it measurable on the dipstick? Where on the ground in relation to the engine does any oil appear, left side, right side, front, rear? How about around the engine oil plug and/or the clutch cover/transmission plug? Give us something to speculate about.
Can you give us more info? When was your last oil change? Does the leak seem to be coming from either of the two oil plugs? Do you see any oil on the engine?
