First issue with my 2013 ST!! Arrrggghhh!!!
I haven't ridden the bike in a little over two weeks. I haven't had any issues until today. Wanted to ride it to work this morning. Started up on the first crank, idled for about 5 minutes while I got my stuff together to take to work. Hopped on the bike (garage kept), took it out of park, put the clutch in and shifted into first gear on my way to reverse - bike lurched a little and died!! Put it back in neutral and tried it again - same results! Any thoughts on what the issue might be???
i did the clutch on a 2012
just type in : 2012 clutch youngers : it should pop up in search area , with photo`s { if this is what you are having problems with , I bought mine used ,5,000 miles on it , think it was from the long life of sitting unused I guess ... you could see where the O - rings rolled and caused the leak } it really wasn`t a bad repair , just time consuming , about 2 full days taking my time not too rush through , the repair , as it was my first dig into the new to me cycle ... now you mentioned easy start , but died when engaged clutch too roll ,, could it be , the brakes ,or parking brakes are still engaged ? there have been a couple of links on that topic also ! good luck in texas ! dang lucky guy ! ;) 70 degree weather and all ... hope this is one of the easy fixes
