Batteries are Good ... Until They're Not
My husband has always used the title phrase. WELLLL ... I got bit by just that very phrase this morning. Did my normal pre-ride checks (tires, turn signals, brake lights, belt, a walk around, etc.) with the F3 still on the tender. Then unplugged about 30 minutes before we were to take off this morning. This is a 2018 F3 Ltd with the original battery .. so, almost four years old. Gear up, turn key, push mode and all is good ... UNTIL, I hit the start button, then everything went dark. What!? So, plan B ... hop on the 2016 RT and off we go. Once we were home, checked the battery and a static test (no load) showed 12.5 volts ... still dead when the key is turned. So, hubby had me take the battery out and he load tested it ... dropped below 10 volts and he also observed a possible hairline crack in the top case. HMMMM ... so, I have checked all the fuses and all test good (continuity). I'm thinking that the battery just doesn't have enough left to open the necessary relays to show anything on the console. But, to be honest, I am troubled that nothing was seen at all (not even some of the odd, crazy, displays that have come up here).
Could I have a bad relay? Is there any way to test the relays (there are several in both fuse boxes, as you well know).
New battery on order from Lamonster Garage .... but in the meantime, I sure would like to feel more certain that the battery is my only problem. Anyone have some sage advice on how to troubleshoot and make sure I've not got something else wrong?
Thanks .... Ann
