message |
constant |
device |
module |
comment |
b0 |
b1 |
b2 |
b3 |
b4 |
b5 |
b6 |
b7 |
example |
020 |
VCM |
bits informing about error in module: vss, vss, -, abs, no parking brake |
default 00, different number if error exists |
00 00 FF FF 00 00 00 00 |
0C3 |
steering angle sensor |
02 01 81 01 00 00 00 01 |
102 |
ECM |
rpm / 64 |
something related to RPM |
engine temp from -60*C |
ambient temp from -60*C |
kPa * 2 (max 126 kPa) |
counter |
crc8 |
103 |
ECM |
throttle lever |
first byte is throttle lever value 00-FF, rest is empty |
counter |
crc8 |
120 |
ECM |
220 |
yes |
TCM |
counter |
crc8 |
0B FE FE FF FE 02 0C 04 |
222 |
TCM |
have only two values |
230 |
VCM |
ABS speed values |
b5 continuation |
km/h * 10 |
300 |
yes |
ECM |
00 -> D3 after moto start |
303 |
YRS |
counter |
308 |
ECM |
bits: low bat, -, -, -, engine hi temp, -, oil switch |
310 |
ECM |
gears: 1-6, 7 neutral, 8 reverse |
changes to 2 when there is ABS pressure and 3 when BLS engages |
counter |
crc8 |
330 |
DPS |
error code, 99 99 - no error |
counter |
crc8 |
340 |
left buttons |
bits: up, down, left, right, menu, set, fron button (com?) |
bits: windshield up, windshield down |
bits: gear up, gear down |
341 |
one time after cluster is connected but probably not cluster itself, more like buttons |
342 |
ECM |
probably vsm error, shows 40 6c after 5s when vcp reports 4044 (C0044) |
400 |
CLUSTER |
byte 6: value from 1 to 3 after parking brake sensor is "closed". BUDS shows that parking brake sensor is "closed" even without cluster so there must be conneciton to sensor in more than one place |
counter |
crc8 |
401.0 |
CLUSTER |
probably time after system energized |
0 |
ss (in hex not dec) |
mm (in hex not dec) |
hh (in hex not dec) |
401.1 |
CLUSTER |
1 |
401.2 |
CLUSTER |
total distance, m/10 on four bytes |
2 |
dist b3 |
disc b2 |
dist b1 |
dist b0 |
401.3 |
CLUSTER |
trip a |
3 |
sec/10, higher bits |
sec/10, lower bits |
401.4 |
CLUSTER |
trip b |
4 |
401.5 |
CLUSTER |
5 |
401.6 |
CLUSTER |
6 |
"ACS level:
0011 1110 lowest
0110 1100
1001 1010
[1100 1000
1111 0110 highest" |
ACS height, higher bits |
ACS height, lower bits |
ACS buttons, 32/16/8 -> not pressed/down/up |
402 |
LCD |
shown after lcd is ready, probably required for starting the motor |
430 |
VCM |
contains brake pressure value (ss ss 00 00 3E 01 0x 3x where 3e rises with pressure, ss ss - 99 99 default, otherwise error code np. 40 44) |
counter |
crc8 |
460 |
PBM |
514 |
CLUSTER |
515 |
yes |
516 |
ECM |
580,581 |
VCM |
only once when VCM is starting |
591 |
LCD |
shown after menu is pressed, probably required for starting the motor |
