2016 RTL Tri-Axis handlebar install question
I'm in the middle of installing Tri-Axis handlebars. Following Finless Bob's videos - tremendous help and more clear than the BRP instructions. Got to the last step of removal and I'm stuck. The center bar aluminum casting has the GPS wire harness running through a hole in the middle but the mount will not fit through the hole and the harness is hardwired to it. Traced the harness down the right side of bike looking for a connector to disconnect and pull through the casting hole. The harness disappears toward the rear without a way to disconnect. Anyone figured out this issue on their's? BTW, Finless Bob's video doesn't address this as he didn't have the GPS.
Thanks
