Looking for upgrade my stock 3 star sliver rims for some newer style rims. I’m guess all 08-14 will fit mines?
Printable View
I'm pretty sure its 2012 and earlier. The 2013's have 15 inch wheels
Even the 15” rims will fit with slight modifications
any of the 14" for sure and the 15"'s with some readjustments to the fender mounting. Thing is keeping in consideration the mph may be affected with the 15"'s....:thumbup:
there's a set of two front rims from a 2010 Spyder for sale in the Sarasota, FL, Craig's list
they look good and are only 80 bucks
This is incorrect. The 15's fit without any modifications or adjustments to the fenders. The front tires on the 14 and 15 inch wheels both have the same rolling diameter. The 15 inch tires simply have a lower sidewall profile. Speedometer reading is also not affected.
The rolling diameter will be the same. The rim offset is different. A GS/RS 14 inch rim has a different offset then a 14 inch RT rim and also different then a 15 inch rim.
