Can anyone help me find the Serial number for a 2016 CAn Am Spyder model RS? I was told that that the sticker was located just behind the front pulley at a very hard to access place but I cannot find it. Can someone help me?
Printable View
The number is on the back of the engine behind the upper mounting bolt. That is up to the right of the front sproket. It is hard to see cause the bolt passes in front of it...:gaah:
This is where it is on my 2015 RT, I only had to remove the side cover and a computer box to see it from the left (drivers ) side. I would think that the number should be in the same physical location on your engine. Can't quite see the number here, but it is just behind the top right grommet on this engine
I was told that the EIN is a 7 digit number after ROTAX 1330 ACE M is that correct? If not, what do I look for?
Thanx
