Just bought he new Garmin XT from Lamonster, can someone please tell me how to wire it in? Do I hook it up to the Battery or fuses? How do I run the wire and what do I need to remove? Tupperware.
Printable View
Where am I checking? Spyder lovers? Google? Website?
CanAm website, look at 2020RT, then Accessories, then Garmin Mount, download installation instructions
It's under the right side panel. The long panel by your knee. The plug is end is small and fits into the black side panel under the one you remove. It's not attached to anything just rests in the black panel.
I cut the plug end off and attached longer leads to it and ran them up to the top cover by the windshield so I can hook it to the Garmin when I get it.
Have an issue with my Zumo on my 2020RTL not charging. Install by tech at Can Am shop, "suppose to be a plug and play"!! 590 Model Wit BRP mount and wire harness for the 2020RT. I can filly charge the unit with an AC plug in. New battery also.
I had the same issue with my new 2020 and with some help from Jetfixer, here on Spyder Lovers (see the link in the video), and some wiring help from Lamonster was able to (watch him) fix it. I created a little video to help others out with this same problem. I had wired it to the headlight breaker and while it worked, Lamonster said that was not 'optimal.' ("Bad" was the actual word.) He did the whole thing in about 5 minutes. It was impressive to watch. The video goes kind of quick to minimize upload/download time, but pause it as needed to read instructions. Note: the BRP accessory/GPS wiring is plugged in to the side of the bike, but goes NOWHERE. It's just a dead end plug. Lamonster removed that, snipped the end of it off, wired in the XT and voila!
https://youtu.be/YGLGiz7Ho9g
