Ya'll help make this community even more fun...needed that... :)
Update...so, I exaggerated some on the 'much less shaking now'...must've been worn out last night testing this thing...
Today's tests after work...belt tensioner is still tied up off the belt. Rides better, but still shaking way beyond what's close to normal highway shaking on various pavements...variation of speeds...still about 60mph is when it starts, gets worse up until about 83mph and then friggin' thing begins to smooth out more at 85.
1. jacked up the bike and manipulated the wheels. They do not move in and out, but there is a rubbing sound when the wheels free spin and they both slow down as if the brakes are on slightly. Does the parking brake do this...? Not sure if that has to do with the shaking, but it's something I've not heard before on my '14 ST-S. I'm not sure if I've paid attn to these wheels for such sounds. This is noticeable. Is this normal? Listen to the video.
Turn up your volume...doesn't have to be loud to notice it.
https://youtu.be/f6rioexm-SE
2. I tweaked the shocks several times and tested it for a while, can tell a difference within the middle range of clicks stiffening.
3. I took off my large Madstad windshield because it flops in the wind more than I like...worth a shot...it helped some...was shocked. But, the shaking of the bike is bad enough possibly it manipulated the aero on the front end making it flop more...
4. But, both of 2 & 3 together seemed to help more...but, still too much shaking.
5. I took off the zip ties from around the belt tensioner and put it on the belt. It made it the shaking much worse...so, I tied it back up. Now, I'm back to 2 & 3...
I just can't her dialed in...going to get the rear tire balanced asap and adjust the belt from 140 to whatever brp recommends (have to look it up). Reminder...currently belt is at 180lbs.
