Cool, I'll take a look at those tires.
My wife is loving it so far, especially as I keep adding farkles. Still on the list are a set of driving lights. I already have the comfort seat, which is very good.
Thanks,
Printable View
Another question. Who sells nose protection for the ST? My wife's leading edge catches the driveway nearly every time. A metal skid plate would solve it. Does anyone make this, or do I need to do it myself?
That is one of my fears. I may have to look at a different option, maybe home brewed.
This is our driveway:
http://i20.photobucket.com/albums/b2...102_124810.jpg
It doesn't look steep, but my car touches too. As you can see it is on a 4 lane road that has heavy traffic at times, so often you are turning left not only going faster than you might want, but the angle isn't the best.
Pulling out is not the problem, pulling in is. If there is no traffic, very rare, it is fine, but usually we have to move quickly while watching our back. It isn't easy living on a busy 4 lane street. There are literally accidents in front of my house every week. :banghead:
Anyhow, do you have actual suggestions on protection for the front lip?
Hey Jim
I have the same machine. Lots of fun, you definitely need the bajaron swaybar. Will cut down on the wandering from cross winds and semis plus big difference on cornering. Mine didn't run well until after the second computer upgrade. Enjoy
Paul
I don't know about an ECM upgrade, I picked my 2013 ST-S up in May 2015. It was new, just a left over, I have not had any dealer shop work done since I picked mine up.
But, I have no complaints about how my Spyder runs, it runs great!!! Oops, I forgot, I did have the BajaRon sway bar and billet links installed and a laser alignment done at a dealer's shop nearby home. Dealer I purchased from is 105 miles from home, the other one is 35 miles away. Oh, I also had the 2014 vented side panels installed. :yikes::yikes:
Jim, If your Spyder does not have the BajaRon sway bar and links installed, you may want to consider it. This vastly improves the handling of the Spyder, it feels like a different machine!!! The factory links are plastic, the BajaRon links are billet aluminum, much better!!!!
[QUOTE=JimVonBaden;1203589 Anyhow, do you have actual suggestions on protection for the front lip?[/QUOTE]
Other than the bumpskid, no.
http://www.bigbikeparts.com/template...9&GroupGuid=78
might help.. make sure to get correct one for your year spyder
Jim, I have had very good luck with UHMW poly, cheap, easy to work with. Mount the poly under the lip and secure with a couple of small screws,(wood screws work well due to the large thread form). the ploy will move if it is struck with the drive way paving and slide over it. Works for me, does no good if you run intp a parking lot bumpers, don't ask how I know.
Good Luck
Hi Jim,
Just passing through and did a search and saw your post from October, Did you ever get a solution for your Glo Ryder wheel lights? If not let me know at sales@gloryder.com and we will take care of you :)
Will
Hi Pete, I used these, then made custom mounts. The mounts that come with them work, but are universal mounts. http://www.ebay.com/itm/Detachable-H...19.m1438.l2649
http://imagizer.imageshack.us/v2/128...924/DjMwes.jpg
http://imagizer.imageshack.us/v2/128...923/jXcUet.jpg
http://imagizer.imageshack.us/v2/128...923/N7w69x.jpg
