1 Attachment(s)
2018 RTL Baja Ron Preload Adjusters- Installed.
All,
Enough videos on this, just to say I'm done installing the Baja Ron preload adjusters on mt 2018 RTL.
Some thoughts:
- Baja Rons instructions are great. Written to the level that anyone can do it.
- The left side top bolt is definetly harder than the right, but not so bad that you can't actually get the bolt back in at the original orientation. I installed by hand the upper bolts with the bolt facing rearward as installed from the factory.
- Baja Ron spring compressors are great. If he doesn't need them back I'll probably keep them.
- Gained about 1/4" ride height, it will probably settle back to the original position.
- I'm skeered of spring compressors, see the picture. Really stabilized the spring/compressor during installation.
