My 2018 RT has 4500 miles on it and a check engine light came on how do I check for a code? Bike seems to be running fine.
Printable View
It's in in your menu under settings.
if you shut the engine off with the key and not the kill switch you may no longer find any codes as they may have gone into storage and can only be retrieved with the BUDS system. If you have the light on start the engine for a bit shut it down and remove the key and let the computers re-set. Have a cup of coffee/beer then re-start and see if the light has gone off. If not re-check for codes or ryde and see if the light comes back on then shut down with the kill switch of check with the engine running....If gone and does not come back and all is well I chaulk it up to a glitch and ryde on....That light comes on for any and all reasons possible on these rydes....:thumbup:
