Fobo 2 Issues - Valve Stems and BRP Connect
First issue... I bought the FOBO 2 for Trike and installed it using the factory rubber valve stems. After reading a few posts about how a TPMS sensor could rip the rubber valve stems off, I decided to have the FOBO chrome stems installed (came with the kit). Well as it turns out the FOBO stems will not work with the Can-Am wheels, they are too short and now I cannot reinstall the sensors. Has anyone else run into this issue? If so what specific valve stems did you use to correct it?
Second issue... It is documented in the forums that FOBO 2 does not work with BRP Connect. Does anyone have an update from Can-Am or FOBO regarding this issue? Has anyone gone back to the original FOBO software using the FOBO 2 sensors?
It is maddening to purchase such a simple product and have to spend time and money to un-****-it. I should have went with the Garmin TPMS :gaah:
Thanks in advance, Bob
