1 Attachment(s)
2020 RT Baja Ron Sway Bar
With great anticipation, the 2020 RT is here at SPYDERPOPS. Here is what we know: The Baja Ron sway bar installed was a great improvement. The Baja Ron sway bar upgrade for all earlier model spyders gave us greater stability, comfort, and control around turns. The 2020 RT was no exception.
Baja Ron has also redeveloped the endlinks. The housing is heat treated chromoly steel. The ball is heat treated with bearing quality, hard chrome finish. Whereas the previous links used a hardened steel ball and steel race with a corrosion resistant, self lubricating coating subject to wear, they occasionally had rust issues for riders who often rode through salt or corrosive environments. The new rod ends have a permanent, self lubricating nylon race which will not wear out.
Install was easy. No more removing all those support frames and body panels like previous years. It was more like installing an F3 Swaybar. Except for removing some splash panels on the bottom to access the sway bar frame channel, there were no body panels to remove. The bottom of the spyder needs to be up about 22" for removal and install.
We look forward to seeing everybody in the shop and out on the road at one of this years rallies. Come by and see us for professional install of the 2020 Baja Ron Sway bar and other great SPYDERPOPS products for the 2020 Spyder RT.
Now available at WWW.SPYDERPOPS.COM as part# SPY393.
