Hate putting air in rear tire.....Hate it.
June, 16, 2021
I love my 2021 RT-S2S, BUT I hate getting down on the garage floor and putting air in the tire and checking it with the different air guages. It seems as though every time I go to put air in the tire I hear all kinds of air leaking, sometimes no matter which way I position the end.
Can you use the valve extensions when putting in air and then remove it before going out ? Will you lose a small amount of air when you unscrew the extension ? If that is the case then maybe I should put in a bit extra to allow for the escaped air when removing the extension. I presume I can do the same with the front tires, even though they are a little better.
Motogordo
