2014 RT Limited Start Up Noise?
Has anyone had a clangy metal noise on initial start up? Noise goes away within 15 seconds after initial start up. Sorry I can not describe it any better. Thanks for your help. The bike is a 2014 RT Limited and has 600+ trouble free miles, no other issues...........except the " key recall ". Been riding this machine to break in for my wife. I am a two wheeler Harley rider...........I must say, I really like this machine.
Thanks for the reply...........
Quote:
Originally Posted by
SpyderAnn01
No, I have never heard that noise on either of the 2014s that I have ridden.
You have much experience with these machines. I am beginning to think it might have something to do with the alternator? I noticed that the sound goes away at the time the lights get bright again after start up. Hope it is that simple..........thanks again.
I think problem solved..............
PMK
I would agree that on start up there is a minor "rattle" that is gone very quickly. Our machine has done it from day one. Not loud, not in any way discouraging, or a worry for me. I sort of felt that as mentioned it was the SE clutch picking up fluid.
If you do run it to the dealer, you may need to leave it overnight, I never notice it after the first start of the day.
Once fired up and warmed up, the clutch and gearbox work fine. With cold oil and a cool engine, the gearbox does clunk into gear getting it out of the garage. Again nothing I am to worked up over.
FWIW, our machine is just over 1300 miles.
PK
That is exactly the noise. After riding and stopping for fuel............no noise. Either the clutch or the lifters? The dealer has not heard the noise, but I don't think they have had many machines to play with yet. Thanks for taking the time my friend.
Four Stroke Inline Triples
Having had two Triumph triples (1996 900cc Adventurer and 2010 Rocket III Touring) I can say they do not sound that much like diesel engines. Think of them as one bank of a V6 engine. The Adventurer had a rather loud aftermarket muffler and at certain RPMs reminded me of a WWII fighter plane (think Spitfire or P51 Mustang) swooping. The 2300cc Rocket had the Triumph performance slip-ons and at 50-60 mph reminded me more of a marine engine (think old Chris-Craft boats with inline six or straight eight engines). I haven't yet experenced a Spyder RT with the 1330 ACE yet but I'm willing to bet it falls somewhere in between the two Triumphs that I've had sound wise.
Timing chain noise when cold started, is this common ,
sddinnh
About the same for me. I thought it was considerably noisier than my 2 wheel bikes, but I have nothing to compare it to, since this is my first one. It goes into the dealer Friday to get the BajaRon bar put on and a few other things, so I'll have them give a listen and see if they hear anything they shouldn't.
When you change oil and filter you expect some noise, but every time its started cold, the timing chain rattle, Anyone else having this problem????? On the chevy 2.2 Ecotec at work we change the chain tensioner, because the spring thats suppose to keep chain tight until oil pressure builds up gets weak, that solves the problem. The 1330 motor has the same type tensioner with spring, but reading all the comments about noise when started, makes me think
its the same problem. On the 2.2 motors its about 2 hours work, but the Spyders its a lot of work
