Originally Posted by
stevencovert
I have changed out several sprockets. Once you get the belt back on, and the rear shock re-mounted, I slid a broom handle through the rear wheel and let it clamp to the frame when torquing the front bolt. Also, look up the new paste to put on the splines. It transfers torque better, but I forget what it is called. I bought a tiny little tube of it. There has been a lot of questions on keeping the spline dry, using high temp grease, etc. but BRP finally put out a bulletin said to use gear grease. Maybe someone here can remember what it is called.
