Brake pedal release leads to VSS Fault
adding LED bulbs this weekend. had rear up on car ramp. checked nanny reaction after each bulb swapped. only after bringing all 3 tires back to ground did this VSS fault appear. upon scouring this site for more information, I already have a new Main Relay on the way, but I also performed 3 key trick, where I turned it off/on 3x quick. mind you, foot was on the brake pedal, but the fault disappeared completely. and as soon as the brake pedal was released, immediately re-appears. like clockwork. repeatedly.
things that make you go "hmmmm"?
FWIW; replaced the tail/brake lights on my 2014 with LED's without any issues.
Super bright LED's standard 1157 replacement in LED format
Quote:
Originally Posted by
CANUSASwede
nothing "standard" in there. just searched "1157". 16 results. 12 are actual bulbs, labeled as "1157" LED Type
I believe if my sieved memory serves me properly you can do a bike specific search to narrow things down; could be wrong, frequently am
Al in Kazoo
