I just threaded through and twisted it. Much like a twist tie for you loaf of bread...:roflblack: Ideally a ring would be better but as I was just using what I found on the work bench I did the same on the split ring...good luck :thumbup: gene
Printable View
Many thanks Gene, Mike et al. Release cable now installed in F3-L frunk. I actually used a flexible 900mm Ipad charge cable. Snipped the iPad connector off, stripped the cable, passed it through the tiny hole next to the release, tied a knot in it and threaded the other end up under the fairly easily removed top inspection panel. It’s still got the USB plug on the pull end, so it’s pretty well disguised ;):thumbup:
Now I’ve gone to all that trouble, I can pretty much rest assured that I will never have to use it :D
Pete
Yeah, Pete......poor terminology ;) There were three smaller coated wires (and some insulation) inside the main sheath, which I was able to pass through the hole next to the release spring. It seems to have plenty of strength for the task and doesn’t interfere with the factory release mechanism.
Pete
