:2thumbs:
http://www.spyderlovers.com/forums/p...&pictureid=480
Printable View
well how's it go?
What is that Juice Box, Lamont, some kind of radar?
Hello, Lamonster... how is you juice box secured to the yellow panel? Have you tested it yet? How is the performance?
One of the reasons I rode today is to have it fresh in my head how she rides.
I spent most of the afternoon installing it and taking pics. To get it to mount where it is now I had to solder a couple of wires to make them longer. The box is hook and loop to the top and I have some blocks under the two oustside ends to give it support.
The hardest part of the install was getting to the injectors without taking the air box off. I came up with a little trick for the right side that worked great. :doorag:
Didn't get to run it yet, hope I can some time tomorrow if the weather holds. I'll report back when I do.
Oh, buy the way I forgot to say I got mine from No Magic:doorag:
http://www.spyderlovers.com/forums/s...ead.php?t=8132
Lamont... I assume you've read the instructions by now.
1. Do I see it right that is may allow changes among eight or so different RPM bands? The old Techlusion boxes allowed just three very wide band adjustments... like a carb's idle jet, needle and main jet.
2. Does it allow you to enrichen AND lean out those bands? No leaning was permitted on the older boxes... it just enrichened the mixture.
:chat: ?????
Near as I can tell you can't take away fuel like you can a power commander. And no I haven't read the instructions yet. :opps:
The system has 6 adjustment modes. Although only 5 (2-6) make any changes to the system.
The system can go as lean as a stock bike, but no leaner. (I think they are afraid that people might get it too lean melt down their bikes, then blame them) Going too rich if you get carried away might ruin a set of plugs, but at least you won't fry anything.:dontknow:
Some of the adjustment modes are for how quickly the box makes the transitions between the different modes, and also how quickly the full on posistion kicks in.
MM
Have you ever had so much fuel that you've washed down your cylinders? I have and that's when I had flame throwers on my Valkyrie. The way the system worked is it would cut the ignition off while you were running and then take that perfect fuel/air and light it off from a sparkplug in the rear of the pipes. It took raw fuel with zero burn to cause any issues. Me and a few other guys did this for over a year before we had any issues.
http://www.spyderlovers.com/forums/p...&pictureid=482
We all had to rebuild our motors after that but it was worth it for the fun we got out of it.
I'm pretty sure, you'll be fouling plugs way before you have a cylinder wash down.
Bad fuel will cause carbon build up faster than too much fuel and I don't see why anyone would buy a Juice box that was running a stock pipe.
There is no fine line on tuning an FI motor as opposed to a carburetor motor. The air fuel raitos are still the same as far as what is too lean or too rich. The only real difference is you have much more control over these perameters with FI.
http://www.m109riders.com/forums/pic...pictureid=2783
While I was searching around for that chart I ran across this.
How to build a 64 hp Stage 1 kit out of a 1340cc evo.
http://www.nightrider.com/biketech/hdbuildstage1.htm
I'm sure glad they put that little 998cc Rotax in our Spyder. :thumbup::doorag:
Found a old video of when I first hooked it up on the Valk. :doorag: It didn't work too good sitting still but it worked great going down the road.
http://www.youtube.com/watch?v=hud3nIs6lIE
:agree: and I hope that anyone who would buy one of these would be somewhat of a gearhead or at least take it to someone who was.:doorag:
and I guess I corrected my post before you quoted it. ;)
Lamonster>
Now that you have spent some time with the Juice Box, what is your evaluation overall function?
Has it provided any mileage increase?
More power when needed?
As to stock exhaust?
I am primarly thinking of mileage performance.
Thanks
Thank you Lamonster.
Probably a dumb question but since I am a Spyder newbie what is the classy looking emblem with the spyder over the ignition? Is it an aftermarket part, a lock or???
That is a one-off Lamonster modification. See the following link:
http://www.spyderlovers.com/forums/s...ead.php?t=4722
Bruce
Very creative - thanks for the information!
Ted
