:agree:
Printable View
What are the size of the speakers on a 2020 F3 Limited?
Has anyone upgraded their amplifier in a 2018 or newer F3 Limited Spyders? BRP stated the 6x20 amp is proprietary and cannot be upgraded. Can anyone establish if this is a truly a fact?
The volume output on my 2018 F3-L is significantly lower compared to a 2017 F3-L (as an example which uses a different electronic dash cluster and audio system that has two amps to drive the front and rear speakers). Even while traveling at highway speeds with a tall windscreen, I can barely make out the GPS navigation instructions let alone the music even with the volume set to 95% or greater on the newer Spyders. Just in case you might be wondering, my annual hearing test confirmed the ears are functioning at 100%. ;)
To be sure the issue isn't isolated to only my Spyder, I've had on loan over the past two years brand new 2018's and 2019's F3-L's and RT-L's which suffered from the same low volume output compared to their predecessor Spyders. The 2020 F3-L I currently have on loan is a tad louder yet BRP claims it's the same amplifier and speaker setup.
I'm interested to upgrade the audio output so I can hear the nav and music. But so far BRP cannot give me anything more. My Spyder tech cannot find anything to determine any difference either between the 2020 and past two year Spyder Limited models.
Thanks in advance for your reply.
I have a 2018 F3L. The audio from my android phone BT connected to the dash is plenty loud at any speed. I am slightly hard of hearing. Too many years of loud toys. I have the volume so high that pedestrians walking on the sidewalk turn around to look at what is coming.
If you have an android phone. While BT connected to the dash. On the phone. Have you answered the warning notice about high volume is bad for your hearing and turned the volume all the way up. That has to done everytime the phone is cycle off and on. Each app has it's own volume level on the dash. So if you want the volume higher for the gps app then the music app. You need to turn the volume up for the gps while it's giving a prompt. Hard to do.
My wife has a 2018 F3T and I have a 2020 F3L. There is a big audio difference between the 2 where hers "pops" at higher volumes and it doesn't play nearly as loud as mine. Both are on the latest software version for the years. But there is a software differece between the 2 years. Hopefully BRP will update the 2018's to the same level as the 2020's, but I'm not holding my breath. I am working on upgrading hers with some Kicker 6.5's and a Kicker amp. No issues thus far with it all wired for testing and that little amp makes it plenty loud. I just received the inner console part so I can start modifying it to make the 6.5's fit and keep the original for just in case... or restoration for trade later. I will do a write-up in the how to section later.. but it will be a while as I have some "engineering" and likely some fiberglass work to do for the speakers.
For enquiring minds, we opted for the PXA 300.4 just to drive the fronts. It has high level inputs and it seems to work well just tapping the original speaker wires. Basically, the stock amp stays in and feeds the signal to the Kicker amp via the original speaker wires. The original plan was to use 2 channels to drives the mids and 2 channels to drive the tweets as there have been reports of the stock system not providing full range output to the woofers and the tweet outputs block lows for sure, but after semi-scientific testing, the woofer outputs from the bike play frequencies higher than we can hear... we tested the tweet output too and it topped out around the same point as the woofer output... so both play fairly high... or our hearing is shot and we can't hear over that frequency anyway... separating the mid and tweet didn't make a difference either. I am using a component set so I can amplify each separately.
So, based on all that, one set of channels will be used for both and i will use the Kicker crossover and just stick it in the speaker cavity.
The other 2 channels I debated using for the rears, but I may try to sneak a Kicker 6.5" (or was it 6.75") sub in somewhere... like maybe removing the glove box and fiberglassing a housing and downfiring it there... pretty tight fit though and not 100% sure I can get enough air volume in the enclosure... we'll see.
TL : DR version... Yes, aftermarket amplification is possible as are aftermarket speakers... it just depends on the size and how much modification you want to do...
This is all good info. The woofer outs are full range? THANKS! Can you give part #'s for the Kicker crossover and all you plan to use? Are these linx accurate?
PXA 300.4? "click: to see PXA 300.4
Kicker xover? "click: to see Kicker Xover
I will say that the woofer outputs seem to be full range. Without access to a real time analyzer I can't say for sure, but using a tone generator on my phone via Bluetooth to the Spyder it played beyond my hearing ability...
Yep, PXA 300.4.
Speakers we are using are the Kicker KSS650 and they come with a crossover.. using these as the local shop was out of the CS series... downside is that the KS tweets are silk dome so need to be super careful with water... the woofer I'm not so worried about... the CS have a titanium dome. But any coax or component in theory will work... marine grade would be best for water...
The 6.5"s one guy said only took minor modifications to the console to fit... his definition and mine are different... it will take some cutting and some fiberglass to make it right... i think he cut a bunch out and epoxied a Rockford 6.5" pod in... there is a YouTube video showing his end result.
Read thru this whole tread and my original question hasn't been answered.
What size speakers will fit a 2020 F3 Limited that doesn't involve cutting?
None. Only the stock will fit without any modification. Noone has found a drop in that is that exact size of 4.5".
Hi,
What is the (electronic) difference between the F3 LTD and RT 2020 ? The sound is very BETTER on the RT 2020.
Thank for your answers
I've been trying with little success asking BRP to reveal this information. The parts catalogue indicates there are no differences between the 2018/2019 and the new 2020 speakers in either model Spyders. The 4.5" proprietary speakers look identical when I had them out side by side from my 2018 and from a 2020 F3s. Clearly there IS a significant difference in volume output in the former model years regardless of which Spyder you have.
Identical sources were used to test volume output differences from the 2020 to the previous model year Spyders.
Example:
- FM radio tuned to identical station set at the same percentage of volume output
- Phone plugged via USB using BRP Connect playing particular song at set volume output
- BT tunes playing particular song at set volume output
It made no difference whatsoever. The 2020 model Spyder (F3's or RT's) volume out is significantly louder by nearly 35% more.
I've requested if BRP addressed the volume output via the software. They can't or won't answer the question.
I added a complete sound system to my roadster
Kenwood BMM 528 Bluetooth radio
JL M400/4 am
Rockford fosgate T series 6x9 2 way speakers for rear bags i installed
Polk audio 5.25 front MM series
Had to custom build brackets for all improvements and add ons but experienced in this
The choices were proven in qualiity from a harley build and used for 5 years now so i repeated the components for the roadster
Insane sound and very loud and clear
I mounted a pair of old harley bags to the rear which i had previously on the harley and exchanged for stretch bags
They already had 6x9 cut outs
I had to build the front speaker enclosures but used materials from Lowes
A combination of PVC 22 degree 4 inch elbows with a 4 to 5.5 inch hose adaptor
Turned out pretty decent i feel
P clamps and aluminum angle were used for the mounting
I uploaded images but not sure if they will show up here
Speakers can be added into the rear side compartments as i have done this before as well
Its just time consuming but worth the effort if you love good tunes
Very creative on the enclosures. Never would have thought of sewer pipe adapters! Did you say you don't use the factory audio at all?
I love polk audio DB speakers. Used 6.25s on my GL1800 goldwing.
"click: to see GL Audio Page
My 18 F3L also has crappy sound. I am bringing it up to a guy who is going to replace all of the speakers with new ones that are much better than the ones I have now. Also connecting a second amp to power them. I am hoping this makes a big difference in how it sounds.
I did a 2017 F3T upgrade a few years ago and used all the factory controls. We are getting ready to do some upgrades on it shortly. Used 2 Rockford amps, 4 JL 1" tweeters, 4.5 kickers in the dash with tweeters, 2 6X9s in the saddle bags.
