2012 RTS SE5
1- Does anyone have the Vee Tire on the back ? If so what pressure do you run in it?
2- Is there any way of adjusting the front Frunk Lid so that it does not move while driving ?
Thank you,
Printable View
2012 RTS SE5
Thank you,
#1...Sorry I don't know, but wouldn't buy one ......# 2.....I have tried all sorts of adjustments and still couldn't get it to stop moving......so I just used some door weather strip foam ( the kind with adhesive backing ) on the upper corners and now it doesn't shake at all..........Mike :yes::thumbup:
Vee tire is the same as kenda as far as tire pressure. Use the spyder recommended pressure and adjust as needed. As for the frunk lid BLUEKNIGHT911 gave you the solution...:thumbup:
tire brand never changes tire pressure on any type of vehicle, tire will tell you max pressure while vehicle
will tell you running pressure.
