My 2015 RT SE floorboards tilt down at the front, is this the normal position? Can they be adjusted up so they are at least parallel to the ground? Short legged so this seems a bit unnatural to me
Printable View
That angle cannot be adjusted. Try it for a while, and see if you get used to it.
(I did! :thumbup:)
Your only other option would be to build up a wedged platform; in order to change the "angle of the dangle..."
Geep I had the same problem on my ST - never did get used to it.
I've been wondering the same thing about increasing the tilt on f3s boards - it's better but again short legs issue..
Will be watching for more responses and ideas
When BRP first introduced the floorboards on the Spyder RT as OEM (I think it was 2014), I was a bit skeptical with the tilt. Turns out, when I actually picked mine up and rode it for the first time, I liked it. Felt very comfortable. Don't know why they did it--but it works for me.
I've known from the get go the floorboards tilted down toward the front but your post prompted me to go out and have a focused look at them. To me the degree of tilt goes with the lines of the bike. JMO.
The forward tilt is actually a good fit to ergonomics. Just think how you actually ride a bike with just footpegs. Usually tipping forward
Noticed a while back that my right side floorboard seems like it is angled more than the left side. I dont know if I had a panic stop or not. dpepmding on the length of ride I stretch ot with the pegs. I dont really notice it while riding just when i clean her up
Dave
