Originally Posted by
BLUEKNIGHT911
I've posted quite a bit about this issue, including fixes ….. I see you have a 2015, if under warranty they WILL fix it. ….. Yes this was a warning, the DESS doesn't ever get better - it does get worse until it finally Fails completely..... that could be 5, 10, or 15 starts from now or the next time..... The latest START procedure ( If you have the Orange screen of death :yikes: ) ….. is move the Spyder about 25 ft. away from where it is parked( if possible ) …. then turn key on - off 5 X's in succession quickly . Then try and start normally …. hopefully the screen has cleared …… If you have to buy the DESS module ( do not buy the Ignition switch - Yet ) CHEAPCYCLEPARTS.COM sells it for about $135.00 …… PM me and I'll help you re-place it …. I did this with " w6ada " …………….good luck ….. Mike :ohyea:
