Originally Posted by
ARNIE R
I probably already know the answer to this question, however, here goes. If one removed the Spyder’s windshield and loaded it into the trailer rear first, what would be the most serious side effects of such a stunt?
The reason for this question is that, after having arrived in FL yesterday, I decided to check the tongue weight of the trailer and Spyder together and found it to be slightly over 300lbs. While the new Tacoma is rated for 6400lbs, there is still a slight sag on the rear end. Since I was thinking that carting it home on the trailer rearward would reduce the trailer tongue weight considerably, it might be worth considering - unless someone can advise me on my stupidity..........:lecturef_smilie::lecturef_smil ie:
