Don't know if this system will screw with the bus.
"click: to see Gurad Dawg Keyless
"click: to see Guard Dawg Manual
I assume you mean the Canbus. There no connections made to the data lines. So I see no reason to have any effect on the Canbus
No mention in the instructions how to deal with the chipped key. But that would not that hard to do.
You are still going to need you key in the ignition for the DESS to be deactivated so this system will have the ability to take over.
All this system does is to prevent the need to actually turn the key. Ultimately the DESS is what is looking after your bike for you.
You could have DESS turned off but there goes any real protection. In that case there is no DESS to satisfy and this little security device thingy acts as your key tumbler. This type of product is not designed to interact with smart systems.
These types of systems are a security risk not an improvement. They are made for bikes that do not have "Chipped" keys. These types of Wireless systems are a joke. They are not far behind the add your own "Push Button Start" add-on for your car gimmick.
I can't tell you how many of these types of "things" I have removed from peoples bikes over the years and have had to rebuild wire harnesses after hack jobs. They have been around for a while. Poor installs and crappy products. This is a lot of money for the purchase and install to save some wear and tare on your key turning wrist. More things to go wrong.
Keep you hard earned money for an oil change! :)
Tim
Thanks for the responses. Could one not have a chipped key somewhere near the switch (say in the glove box) and still use this system? (asking for a friend ;) )
From my experimentation. The key has a range of less than an inch. Simple enough to remove the DESS antenna from the ignition switch. Friction fit. Tape a key into it. Then hide it under the body work somewhere.
I actually did this with a Ford Windstar van we had. I wanted to add a remoter start to it and found that I needed an additional $450's in "modules" to make it work. Nope!!!
Hacked a key off and lightly wire-tied the head to the coil (antenna) that was around the tumbler. Problem solved. :)
Tim
Well... you could. See my above post. It has to be very very close as Billybovine mentioned.
But like I said...I still think your better off with-out this. It offers not real benefit to you or your bike. If your scared of forgetting your key or losing it, have key a hidden one on the bike. I do this with my Goldwings and all the other bikes too. If you use this and set it up the way they want you to then you are up the creek if your FOB battery is dead or dies or the unit lock up or malfunctions because the original key tumbler is cut out of the circuit.
Tim
I would not do it. Not really worth the expense and labour in my opinion. But I would like to see someone else do it out of curiosity if it does work and if any issues come up.
This is a misconception. Since the DESS system has a defective design, it offers no security. It can be disabled with no key present. Its only function is to inhibit the owner from using the bike when wanted. Disabling the DESS does not decrease security, it only increases reliability since the system was implemented with security holes big enough to drive a bus through. The 2008 thru 2013 system actually did work and was secure.
