Would really like to know, where would be the best place to go to get the LED light installed? And would it make a big different on F3 daytona also fog light?
Thank you
Printable View
Thank you
If you find doing that too daunting, even after reading about it in the owners' manual, there must be a Spyder ryder in your area who would be glad to help out. If I were close, I certainly would help. But alas.
got mine from triceled or slingmods also sells them. HUGE difference in light for the LED fog light from them too. I installed them myself. it was not too bad. just take your time taking off the fairings.
Lamonster has the LED's with install video which is very helpful. Most of the job is removing the plastic panels. Once you do that it's 4 bolts per headlight and a simple bulb swap.
I got both fog lights and head lights in LED form from Lamonster Garage … the install videos are very easy to follow. Like amcvay1979, I did the installs myself .. fog lights, then fog rings, then head lights. It's really not that bad … the hardest part is gaining access to the area by removing a few panels.
Hopefully, someone will chime in from your area that is willing to help you do the job. If not, watch the videos and either post questions here or email Lamonster Garage … they are always very helpful.
Good luck with whatever you decide to do …. Ann
