Where do you find all the codes for the Spyder on line or is there a book that you buy from a dealer.
Printable View
Download the SpyderCodes App for your smartphone: that should keep you well-informed! :thumbup:
Got this code today any help?
CPS crankshaft position sensor. You would need to check the sensor connections and that it is installed correctly as well as the connection to the ECM engine control module. In many cases it can be a fluke caused by some hic-up and the code will clear after the computers reset. :thumbup: if it clears and then comes back next ryde and you can not find any loose connections then run it by the dealer. It will be the sensor cause it is not likely that your crankshaft moved out of line...:roflblack:
Where would you find this sensor?
Based on other peoples experience posted here. The sensor has gone bad and needs to be replaced. But it is never wrong to do a visual inspection first.
