Originally Posted by
OZZ3
Ron, thanks for the (?) in respect to the oil, it actually has about 2K miles on it , was changed last fall on my buddy's RT SE5 at the same time I changed my SE5's . By the way I believe we or I have purchased the oil filters through you and replaced my front suspension bar from you. Norm is in the process of changing the oil on the RT SE5 today or tomorrow because of the issue described I mentioned to Norm to closely inspect the oil plugs on removal. Our Can Am's both have magnets in both plugs and of course aluminum scrapings from outer clutch cage slide groves are not FE. Also inspect the filters removed. O yes, the clutch plates were replaced last year with the new style along with the centrifugal clutch release "coil spring" and has been running fine with excellent engagement up until now on cold start.
Ron do you have access to BRP Spyder SE5 clutch mechanical engineering, I would like a valid answer to the above question about the pin forcing use of one set of three selected slots in the SE5 drum assembly when there are actually three more sets of three that could be used by the centrifugal clutch unit ??? I have pictures to define this issue.
