Ok so getting big orange Brake Failure on screen. Also red parking brake light comes on. Both are intermittent while driving. Is this as bad as it seems?
Printable View
Just needs a little brake fluid added.
:agree:
This is where I'd start at least. When I had just purchased my used 2015 that light came on and the bike would roll after being shut down. Freaked me out because I was still getting to know everything about it. But yes a little brake fluid took care of the problem and it really hasn't needed any since. Put it in by the cap full. It doesn't need a lot usually once the light comes on unless there are other things going on.
Read your operator's guide; it will tell you what brake fluid to use and, no, you can't mix them.
:coffee: Did Adding A little Brake Fluid Fix the Problem? .......:thumbup:
One little detail that you should be aware of. There are only two reasons that the brake fluid will be low.
1. There is a leak. The leak could be at any one (or several) of the MANY joints in the system.
2. The brake pads are worn. As they wear, the pistons that push them move, requiring fluid to take up the space behind them. This is particularly noteworthy if you add fluid now, then replace the pads. When you replace the pads, the pistons need to be pupshed back into the caliper, which pushes fluid back into the reservoir. If you had recently added fluid, it might overflow out of the reservoir.
1 more question... How many cap fulls should I add? I'm not in a place where I can bleed the brakes so don't suggest that.
Usually not much should be able to see min/max lines on reservoir may need flashlight:lecturef_smilie: don’t forget “on level surface”:lecturef_smilie::2thumbs: some go by the “floats” inside reservoir, enough to get flush with top of ring they sit in. Do suggest noting mileage & checking remaining thickness of pads. :2thumbs:
Update??
