Cooling Fan Manual Override Switch
Well as I indicated in a previous post I intended to install a manual override switch for the cooling fan. Well this morning I finished the mod. Basically what I did was take a 12 volt source through a fuse (15A) and switch (25 amp rated) to the 12 volt power line to the cooling fan AFTER the fan relay.
I installed my fan switch in the dash and connected my fused and switch power line to the fan power line via a posi-tap connector. prior to actually making the connection and based on previous postings about mixed up BRP wiring I verified that the fan wire I was going to tap into was actually the power side and not the ground side. All wiring was placed within wire protectors and all ends were soldered and heat shrink wrapped.
After the installation I ran a 2 part test to verify proper operation. I started the bike and immediately and successfully turned the fan on with my new override switch. I then shut the fan off and let the bike warm up until the computer switched the fan on. With the fan running by way of the control signal from the computer and then turned my fan override switch on. The fan kept running and there were no complaints from the computer.
Attached you will find various pictures of the process. I apologize for the quality of the picture showing where the posi-tap is connected.
