Nice job dan you pointed out a few things that i would not be aware of. thank you. :clap::clap::clap::clap::clap:
Printable View
Whenever I am in this fix, with something that "gives" when it is tightened, I use a 3/8" drive ratchet, and choke up on it, putting the extension or socket between my middle and ring fingers. That way I can only get so much torque on it, like a screwdriver. Maybe it takes some experience to get the feel for it, but it has always worked for me.
:2thumbs:I am going to replace mine in the next few days.Ordered 2 y gaskets ($15.00 each )from the honda dealer
I just did this last night. Thanks for the write up. Took me 1 hour with removing the panels. My honda dealer only had them in a sealed 3 pack but they cost me $13. 10 times easier than I thought this would be.
Chuck
:thumbup:
Dan, a great write up. A perfect example of what is so great about this forum, like others have mentioned, now when I do this, I know just what to expect.
Thanks,
Tom
:2thumbs: replaced my y gaskets yesterday. may I make a suggestion that you put the gasket on the small end of the exhaust pipe as it will let the y pipe slide on easier.
First let me say... WackyDan... "Great presentation".
Last time I bought the honda gaskets they were $8 each and I bought 20 of them. However, I have know for years that anything in Lake City FL is higher than most other places except the "gold coast". Ken krb1945
Guess what I did today? I replaced them with the Honda gaskets. Only 9,000 miles! It was uneventful, thanks to WackyDan.
I got around to changing my "Y" gasket this morning after a 12 hr shift last night. I say gasket singular, because there was not one in the right side. No remnant of one ever being there. I didn't even have to loosen the clamp. When I took off the spring the pipe just slipped off. I wonder how long this had been that way. I'm going to have to pay more attention to the spyder when it comes back from the dealer. I had the 2nd update less than 1300 miles ago.
The whole procedure start to finish took a little over 2 1/2 hours. Working by myself. I ran into a few obstacles. Lost 1/2 trying to get the right side back on, but the KM highway bracket on that side kept getting in the way. I'm sure I missed some obvious trick. Once I removed it the procedure went like this thread indicates. If you have an extra set of hands? Use them! If not? It is not impossible, but will probably take longer.
Add me to the Y gasket replacement team. I went with the Honda gaskets. :2thumbs:
David
So how many gaskets are needed to do this install? 1?, 2?, or 3?.
Y
There is a 3rd gasket, after the two pipes merge into one, gasket part number is 707600350 or 707600547....Are people finding that gasket also needs replacement, and is there a better brand to use than OEM?
Just a follow-up FYI on my exp.
When I got to the BRP gaskets they both looked a little overly "smooth" but 100% intact. Of course since I was already there I pulled them both out and replaced with the Honda's. Spyder had 8,000 hard earned, hard ridden miles on it at swapout but after reading the threads surely I expected them to be at least a little fried. :dontknow:
Makes me wonder if it was worth all the effort. :popcorn:
I'm in the process of replacing my y-gaskets, I've got all the parts and I have dropped the muffler and the Y-pipe. I removed the electrical connection for the o2 sensor so not to worry about putting weight on the wire.
Now, when I picked up my new gaskets and straps, I was talking to a mechanic who said that he used, Permatex (sensor safe) Ultra Copper High Temp RTV Silicone, on the new gaskets to prevent premature burn out. He also stated that in the three years on doing this he has had no complaints from customers or had to replace any. He works not only on Spyders but Harley's, Honda's, Victory, and custom bikes.
I was wondering if anyone here has used this product on their seals?
Done! Used a crescent wrench to widen the female ends of the pipe, this allowed the gasket to slide in with no mallet needed, and anger management was not required. :D:D I coated the inside of the gaskets with Permatex and they slide on effortlessly. I'll give it a run tomorrow to check for leaks and reduced heat.:chill: My left gasket was almost completely burned out. Right one and the lower one were in great shape. Heat wrap is the next project. After I install my new LED rear side markers. Waiting for fedex to show.:gaah:Now!!
