2021 RT LTD dash display mode - setting 'Auto' light sensitivity?
We just upgraded from a 2012 RTS to a 2021 RT LTD and are so happy with the new bike. The only complaint I have is the display... when set to "auto" mode, it starts with the black background and may not change to the white background for an hour or more in bright sunlight. Is there any way to adjust the sensitivity for this? I've taken to setting it to white background as a default and manually setting it to black background at night, but would like for this to work properly in "auto" mode. Ideas?
If this should be in the tech section, please move it.
Video instruction for changing display mode
Ok, I pulled out the camera and did a very quick and super-dirty video on changing between Dark and Lite mode on our 2021 RTL. Key ON, engine OFF (engine can be on but bike must be STOPPED). Hope it helps (hope you can see it OK). I tried one up a bit closer but it was already in Lite mode and everything washed out.
https://youtu.be/Aa5PUFwMYrE
