Criuse control and shifting problems with a 2015 RT
I have a 2015 RT with 5,000 miles on it.
I have been having the following problems.
1. After about 15 min. of riding, the Cruise Control stops working for a while and comes back to life for a while and then goes out again.
2. During this period, sometimes when I shift up to, say 5th gear, it slips back to 4th gear. If I stop for a while, the shifting, once again works OK.
I wanted to try and check the Clutch fluid, but could not find anything in the manual that identified where this was done. It shows in my manual that the clutch fluid is on and behind the left side of the handlebar behind the control head. Not there....
I cannot find anything anywhere that identifies where the Clutch fluid is on anything newer than a 2013 model.
I did check the brake fluid and the engine oil and it is clean and shows full.
Thanks for you help.
Bob S.
