For 2008 gs sm5
Printable View
For 2008 gs sm5
Here you go. Little pricey but well made/
https://rivcoproducts.com/shop/can-a...and-gs-models/
Or buy some 4" dog bone risers and make you own. That is the route I took.
https://www.ebay.com/itm/NOS-1970s-D...QAAOSwj0NUgK8g
If you need any info on building them yourself give me a hollow and I might can give something to help you do it.
David
What kind of riser do you need/want?
Cut or no-cut? No cut blocks give you 1"-2" rise without cutting your bars to pieces, and can re-use your stock control cables. Cut ones require you to permanently cut your handlebars and *may* require longer cables.
How much rise and / or how much reach back do you need?
If you can find them used, Heli-bar risers are no-cut and give you 2" up and 4" back.
Can Am riser blocks are still available if you only need a little rise.
https://www.ebay.com/bhp/can-am-spyder-riser
We used the Helibar option. I can't recall if I also used a riser block. I'll have to check the spare parts bin.
I used Helibar 5" risers on my 2009 RS. Don't know if they still make them but I loved the diff. they made. Had enough cable to go 5" up and 2" back. You can see how I sat if you go to my website.
Ride in comfort,
John
What are easyest 3-4”risers to install cost is not an issue
I have what you want :yes::yes::yes::yes::yes: just call me, 209-887-3283
Ride Safe
Dave
Evening.
I am looking for a no-cut riser for 2012 RS S SE5
Are they still available?
Looking for no cut riser for 08 GS SM5
