Hello,
Does anyone know of a flag post that could fit in the antenna receptacle on the left of the back trunk? Thanks.
Printable View
Hello,
Mounting a small flag there is a cool idea. Sadly, under the plastic cover and bodywork, on tne left side is no antenna mount. The provision is provided in the molded plastic, however, the actual mount itself is not there.
If you care to add the mount, purchase the mount from the right side, plus the associated mounting hardware. Initially, when I was planning to add the second antenna, my thought was to keep cost low and make the stuff myself. After pricing the oem right side mount, while not free, the cost was low enough I just purchased the parts.
Interesting. So I assume the right and left mounts would be the same. So if I add a mount on the left, where do I find a flag pole that fits?
This is going to be a silly question, but can I just stick a small flag on the existing radio antenna?
Thanks!
Have you thought about just adding flag post / posts to the trunk. I have two post that mount to the trunk. http://store.valueaccessories.net/Tr...mSpyderRT.aspx see this set. and video.
That's an option. How does that install? Any drilling or removing parts needed? Thank you.
Click on the link and watch the video.
I have the same flag post from Rivco that is posted on the link above.
