My husband is building a flatbed for my Spyder and his Harley. Does anyone know the ramp distance, bed height etc. to load the Spyder? Thanks
Printable View
There is no set height for the bed ….. I made a flatbed for my Toyt Pk-up , it was 29 inches from the ground = terrible , but I had no choice..... with 10 ft ramps I could still load the RT. ….. When building from scratch you have to consider the suspension / axel clearance first …. then try and get the bed as low as safely possible..... some folks claim a drop tail design is the best thing since sliced bread ….. maybe easiest to load , however it will cost you at least 5 mpg from the tow vehicle..... search the net there are hundreds of trailer designs you can chose from …… PS axel placement is very important, you want fairly equal balance F to R, but make sure you can have enough weight for the tongue, otherwise it will be all over the road while towing …..good luck …. Mike :ohyea:
