Tire replacement question -- non-OEM tire
Does anyone in this forum know of a dealer or tire service center in central Alabama who is willing (and capable) of replacing the stock Kenda rear tire with a non-OEM tire?
I've only gotten 6500 miles out of the stock Kenda, and I'd like to try another brand (almost anything else lasts far longer; see the general discussion forum), but all the dealers I've queried won't replace the tire with anything but the crappy OEM Kenda. Apparently BRP is leaning on them about this.
I live just north of Montgomery. Thanks!
TIRES AND THE COMPUTERS ON THE SPYDERS
Quote:
Originally Posted by
ThreeWheels
I think it has to do with liabilities. The VSS and other systems have to work within certain tire parameters.
It should be a simple matter to identify and specify these parameters like cars and car tires, but the easier way would be to test the systems with specific tires.
How many spyders are there ? 100,000 ? That's only 300,000 tires total. That's not really a lot of tires, not in the world of the tire manufacturers.
I suspect as time goes on and there are more spyders, there may be more OEM tire selections.
Just my opinion, I could be wrong, and I'm certain someone on this forum will let me know about it.
Think about what you are suggesting and how it relates to the real world of Computer controlled Vehicles ......All cars and trucks today have systems in place that coordinate with the computers, tires , and the various safety systems ...Right.....Do you know of any Manufacturer that requires you to use a SPECIFIC TIRE because that's what the system is designed to recognize ???????........... Do you really believe BRP had KENDA design a tire Specifically to interact with the Spyders Computer System !!!!!!..... and anything else isn't going to work as well !!!!.............BECAUSE IF THAT'S TRUE .....THEN IF KENDA CHANGES THE TIRE COMPOUND .....ALL SPYDER COMPUTERS HAVE TO BE CHANGED .......UNDER WARRANTY .......:gaah:.........I don't see that happening .................... Mike :bbq:
