2020 RT, What should it sound like ?
Hi, I'm reaching out from Turkey. I've owned various Spyders: RS, RTS (1330), F3 limited, and now a 2020 RT limited. I believe I am the first owner of a 2020 RT in Turkey, and I do not have any references that I can compare.
I've noticed some sound differences from the other model's that I've had:
When going at 90+ kph (56+ mph), I get this high pitched noise (https://youtu.be/5xd_3PLsjk0). When I apply more gas, the noise gets louder. When I lower the gas, the noise goes down. When I stop the gas completely, the noise goes away. It does sound like a Supercharger hum.
When going at around 60-80 kph (35-50 mph), the sound profile changes to a sine wave, and it gets a lower pitch (https://youtu.be/oB3HirYwJrs). You can hear the sound even when there is no gas. Also, the tone changes when slowing down or speeding up.
I've made sure the belt tension is set, but that did not change the sound. Is this expected from this model? If not, what could be the issue? Is it safe to ride, or should I stop until I figure out what is happening?
Thank you!
